Under powered Amp
  • 4
randomguy0o1
My amp (900w RMS) is being powered by a 750w computer power supply. When I turn it up, it acts just like I have it hooked up to a battery. Nothing shuts off, it doesn't sound quite, and there isn't any distortion. Is it bad on the amp to turn it up to the correct voltage (square root of rms*ohms)?
Specs:
AMP- Hifonics Brutus 1516.1D @ 2 ohms (900w rms/1500w max)
SUB- Sundown Audio SA-15 D4
BOX- 4.1 ft^3 @ 32hz
Need to know the amperage capabilities of the power supply, that will be the limiting factor assuming you're passing somewhere around 12v. Otherwise you risk starving the power supply in the amplifier.
Just look for the power LED on the amplifier to blink or dim during musical peaks. That's a sure sign that you've hit a limit of what the power supply can do to feed the amplifier's needs.
Thank you. The light dims very very very discreetly. I really had to focus on the light in order to notice that it was losing a little bit of light at the low notes. The power supply has 4 rails and each have 18 amps, all running on 12v of course.
check voltage with a meter, thats the only way. it depends on the power supply as well most are underrated and overbuilt if they're high quality
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
When you random through your music library, you know you got your gear dialed in nicely.
18
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
randomguy0o1
randomguy0o1
Carthage, MO
Jeffdachef
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
