Bazooka amp trouble. Bazooka BA 1500 not powering on.
  • 2
Mike Irish
CarAudio.com Newbie
Just purchased a bazooka amp (BA 1500) & a 12" kicker L5 used. When I hook up the power & the ground for the amp it will automatically go into protection mode. After a little time thinking on it, I decided to unhook the sub from the amp to see if that changed anything. The only difference is that it takes about 5-8 seconds longer before it goes into protection mode again. It has a 4g. power wire & 8g. ground wire & 3 new specified 20a fuses. What could be the problem here?
Thank you.
That's what I'm thinking too. I took the cover plate off to see if I could smell or see anything burnt up. It didn't appear to be, but that doesn't really mean much tho. It's trash now.
PIck up a taramps hd3k or md3k off of amazon for less than $200. Turn the gain down and order a voltmeter to wire to the amplifier input terminals.
6
82
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
262
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
283
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
350
Mike Irish
CarAudio.com Newbie
Mike Irish
Roanoke, Va
wew lad
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
