Before I buy I want your opinions.
  • 1
speedyjuarez
Premium Member
Premium Member
1. Closed cell foam= Ensolite peel and stick vs overkill
2. Mass Load Vinyl= Luxury vs home depot acoustical barrier
I have already ordered 30 sq ft of B stock damplifier pro, and I already have down some Xplicit audio GP stfu deadener.
I'm not looking for the most expensive or least, I just want a better sounding system and drive.
Thanks guys
Just some updates incase anyone cares.
Just did my two back doors on a 99 Tahoe.
Outer skin= Layer 1 -Second Skin Damplifier pro B stock 80-90%
Layer 2- MLV -home depot grade 100%
Layer 3- CCF- RAAMaudio Ensolite 100%
Layer 4- Thermal barrier -home depot grade 100%
Inner skin= Layer 1- Second Skin Damplifier pro B stock 90%
Layer 2- MLV-Second Skin Luxury liner 85-90%
Layer 3- CCF-Second Skin Overkill 100%
Was this over kill?
My subs fire towards the rear so I thought this should be the best deadening possible. When the doors shut there is a solid dud, and my rear end feels heavier when I drove around.
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
560
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
3K
Hell... Run It!! If it sounds good to you. Then that is what matters the most.. Your OWN EARS.
6
This option is better because you need 3 pairs of RCA cables. Tweeters, midrange, and bass. You then use a Y at the amps on the Bass run, then use...
8
3K
speedyjuarez
Premium Member
Premium Member
speedyjuarez
Live in Hobbs, NM. From Ft Worth, TX
speedyjuarez
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
