sunroof not working, is it hard to tear ceiling down and put back up??
  • 1
mrpep
chicago
I have a toyota highlander and the sunroof stopped working, the track teeth broke which jammed up the movement. I can get the parts for 250 and installed for 250 so 500 for the job or I can do it myself and save 250.00. How difficult is it to remove ceiling and put back together?
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
6
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
8
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
mrpep
mrpep
chicago
mrpep
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
