Best Ground
Fender5
Arkansas
Should I ground the battery where theres an existing bolt?
or where i drilled one
thats where my amp is grounded right now.
is it safe to ground 2 amps, and a battery to that same piece of metal. i would drill 2 more holes and sand those down too.
or ground battery in the first pic and ground two amps in the 2nd pic?
so ground all 3 at the same place in the 2nd pic?
thats a good 3-4 feet from the position of my rear battery. Isnt that too long
im not exactly sure where that bolt is in pic one. I think its under the rear deck holdin something
Like I said, the best ground is the one with the least resistance. A 4ft cable run using the appropriate cable diameter won't give you any noticeable resistance.
If this was so you could only have one amp and no battery.. think about.. the car is all one big piece of metal.. well what you would be grounding too anyways..
so are you sayin that a 4 ft ground of 0 gauge wont make any noticeable resistance?
most amp wiring kits give u a 3 ft ground wire..i dont think 4 would make any/much difference
alright cool cool.
im gonna ground the battery and two amps on that same piece of metal in the 2nd pic
Why wasn't this corrected? NO. Your battery negative is NOT ground, its battery negative. Chassis is the ground. If battery negative was...
15
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
691
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
582
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
749
Fender5
Fender5
Arkansas
Fender5
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
