Best settings on A kicker CXA1200.1
Jose Barragan
Corona
So I have a 12” Kicker Comp Q and a kicker amp CXA 1200.1 I don’t think it’s hitting hard like my other amp
Caution: Find out the output of your head unit (check specifications) and match to the gain setting on your amp. The gain setting is not a volume control. If it still is not hitting, you have other issues.
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it to 80 hz 12db. Turn bass boost off turning it all the way counterclockwise. Gain depends on your head unit voltage and where you set the subwoofer level control and source level adjustment.
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
263
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
447
697
Jose Barragan
Jose Barragan
Corona
2RZ-FE
    May 10, 2024
3toneEYZ
    May 10, 2024
