best subs
  • Thread starter <95cobraR>
  • Start date
  • Replies 4
  • Views 2K
  • 1
<95cobraR>
Guest
will one 15 hit harder then two 12's?
15 - 800W
two 12's 800W
both in a ported box
i have a mtx amp that pushes 800W rms
and have two 12's that handell 400w rms
will one 15 hit harder?
Depends on the make and model of the subs. As a general rule, 2 subs push more air than 1 slightly larger sub like jrmax explained. Also as a general rule, 1 15 will hit slightly lower bass notes than a 12, but like I said it depends on the make and model of the subs.
jrmax, did you go to 6th grade? the area of a circle is pie x radius squared. the area of a 15" would be 7.5 X 7.5 X 3.14, not 15 X 3.14. Come on, use your head
Wow sorry you are right man has it been a long time. Well anyway it still comes out to the 2 12s having more airspace so no harm done thanks for the awakining.
Will do. Should have it figured out by next week
24
4K
Was thinking missionary, can really take a pounding that way
9
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
4
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
282
Guest
jrmax
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
