Big 3 upgrade problem
Alright, so I did the big 3 upgrade today hoping to keep my headlights from dimming and my voltage dropping to 12. I am only running 2 12s that are 150 RMS each, and I still get headlight dim. So I installed the big 3 and started my car up and I still get voltage drop and headlight dimming. Any ideas where I could've gone wrong?
Couldn't tell ya off the bat. But it wouldn't hurt to go over your connections to see if they're tight. Could have missed something. It happens.
Alright, I'll check them as soon as I can and make sure the surface they are on is clean. Is it alright for the engine ground and battery ground to go to the same spot on the chassis?
Yup. Most people choose a diff grounding point from battery to ground because typically most of those are grounded to sheetmetal and they wanted a more solid connection. Make sure no paint is in between connections. Could also be that your battery and/or alt is starting to go bad causing this issue.
I don't think it would be the battery or alt. I replaced the battery last summer and the alternator 2-3 months ago. But I'll definitely check my grounds.
---------- Post added at 06:39 PM ---------- Previous post was at 06:38 PM ----------
FSD audio 700D amp, the car is a 2002 Chevrolet astro
Just because you replaced them doesn't mean they won't go bad. I've boughten those items before and went bad on me months later. Those 2 are just reman many times over. Who knows how many people have used them before you buy it. Just use the warranty and exchange for another. Get both load tested just to be sure. @adulbrich any thoughts buddy?
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
943
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Darkspartan239
Ocala, FL
marc2112
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
