BK1800.1D AMP Keeps Going In Protect Mode
  • 2
hutt132
US
I have a BK1800.1D amplifier ONLY hooked up with 0 gauge power wires and the remote turn on wire. The positive wire is hooked straight to the battery with a 150amp fuse, and the negative wire is about two feet long and bolted to a stock bolt in the trunk. I sanded down the paint before attaching it. For the remote wire I have an Add-A-Fuse plugged into fuse #32 in my 2006 Acura TL with a 20amp fuse in the top slot, and a 7.5amp fuse in the bottom slot.
When I turn on my car the amp powers on and goes into protect for a few seconds, then out of protect for a few seconds, and continues this.
Is my amp bad? Did I do something wrong?
When the car is on the power terminals on the amp measured 14v both when it was and was not in protect.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
161
6
393
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
702
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
506
hutt132
hutt132
US
hutt132
