new amp / insides/ loc jumper help
  • 1
bizzlejake
2012 Mustang gt w/ shaker 500- factory amp pushes 2 dvc 8" subs in doors
I had added a 10" sub to factory system using a lc2i. I have now replaced all factory speakers w/ jl components in the doors, 5x7 coaxials in the rear deck powered by jl 700/5 through lc7i. I have ran signal from the fronts and rears. the original sub install used the signal & 12v from the factory amp. I have not been able to get the whole system to operate so Im looking for advice.
Questions and issues:
1) What should the jumpers be set to on the lc7i?
2) should I bypass the factory amp? no audio when the signals from the factory amp are not installed
3)The only time im able to getr audio through both, the fronts and rears is when the amp is set to 2ch.
4) I have not had any actrivity from the sub
6
158
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
381
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
361
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
417
bizzlejake
bizzlejake
houston tx
bizzlejake
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
