Blackbrick 15" sub
  • 5
Looking at the pics, I can tell ya now those lead wires will be slapping the snot out of the cone 🤣
No no no, it was designed that way. As the sub breaks in, the coils burn off excess and become more prone to heating. The extra travel allows those temperature management prods to install new heat management vents on the back of the cone. Very high tech indeed.
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
253
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
341
The best shallow that I've heard is the JL by far. One good regular 8" sub on a 1K would probably be all that you need. Two 8's in 1.5 cubic feet...
11
475
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
418
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
324
1aespinoza
1aespinoza
Pharr, Texas
spokey9
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
