blown orion xtr2400
marcotheclepto
Blown Orion xtr 2400
blown
100+ shipping
(List pictures in this section, 1st p Editing this post with more pics doing everything from phone so its a slow roll
Uploaded with ImageShack.us
Uploaded with ImageShack.us icture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)).
well, had 8 ga wire instead of tinsel leads (mistake) on some subs i built. too much moving weight, positive from one sub's coil broke and touched negative side. sound cut out. @ high volume turn volume down and didnt sound right. turned up a little and pop! hit kill switch and opened trunk magic smoke. then ivestigated reason and found the broken lead wire tocuhing opposite terminal and singed. figured thats the reason.
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
975
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
marcotheclepto
marcotheclepto
United States
marcotheclepto
