Blown output transistor, can I remove it and just use a different channel?
  • 2
Hey guys, I have an amp with a blown output transistor (ADS p640). I'm only using 2 channels and it has 6 channels. Is it possible for me to just remove the shorted transistor so it doesn't blow the fuse, and use channel 3 instead of 2? This is mostly just to test the other parts like the PSU.
If the transistor isn't being used, it won't matter if it's missing, right?
Thanks,
Panda
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
936
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
roaringpanda33
roaringpanda33
Richmond, VA
wew lad
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
