Blown subwoofer
  • 2
dylan07
I have Crunch GPV 2100.1 amp Polk Audio db1222 woofers. I think I have blown woofer because both woofers stop randomly and one of them has a rattle at certain frequencies, and when they stop working i gently move the rattly one up/down or in/out and they start working again. I assume they were wired in series and thats why both quit working. What exactly has failed in the subwoofer, and with knowledge is it repairable? If it's the voice coil I most likely won't try to repair it. If its the spider, cone or such I might try it...
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
974
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
dylan07
dylan07
Sacramento, CA
Boomin_tahoe
