Boost Issues
  • 3
JustinStone
aspiring nutrient
89
13
Florida
Purchased a diablo intune i3 8345, and put a tune on the Cruiser. The boost wasn't making the numbers advertised, and talked about on forums, so I got to tinkering. The stock SRT4 wastegate opened with the slightest pressure to it, so about a .25" shim was added to stiffen the spring. This allowed for 2 more pounds of sustained boost but i still have an issue. My boost spikes at 13-14psi around 1-4k rpm, then begins to rapidly fall as I increase in speed, reaching as low as 7psi. An audible whooshing sound is heard, much like the blow-off, around 7-14psi while still on the throttle. Stock SRT4 BOV's are supposed to take upwards of 20psi so this failure doesn't make sense to me (I replaced the BOV with a spare and no change).
Does anyone have any suggestions?
Boost leak tests aren't impossible with our equipment, just a pain in the ass since the engine bay is tighter than spandex; so I'm tryna save some trouble.
Similar, yet probably unrelated topic. The turbo flutter I had, has disappeared. I understand that flutter is surge, and the BOV is to reduce this, but tbh I was a fan. A 45mm turbo should despool for a good while, so the disappearance of it, especially with 2-4 more psi, has me concerned.
I tried to find a sense wire on mine and couldn't. Maybe I'm missing something .I'll see if it has a temp sensor .I'm trying to get up to around...
980
Odds are that the factory subwoofer isn't going to be able to handle any more power than whatever they put to it at the factory and you would...
It's hard to find the old fashioned stuff anymore actually. Glad the new unit has the features you like. In future I'd always suggest calling up...
8
JustinStone
aspiring nutrient
JustinStone
Florida
sherwood71
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
