Bose factory radio replacement 86 Corvette
  • 1
Hi, all! First time posting...
I want to replace my factory Bose head unit in my 86 Corvette with a Retrosound Newport radio that I've already bought and received. Now, as some of you already know, the Bose sound system in these cars is far from normal... each of the four speaker enclosures also houses an amplifier dedicated to that speaker. The speakers are 1-ohm each and the head unit sends a pre-amp signal to each amp. Here's where my knowledge falls a little short: the Retrosound radio has pre-amps out for each channel. Why can't I simply send that signal to each of the amps and be done with it? Does the fact that the speakers are only 1-ohm affect the type of pre-amp signal coming into each amp?
Derek
My vehicle also has Bose as the premium option. The same thing was said about climate control for the RX 8. A previous owner replaced the HU...
4
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
4
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
monsolo69
monsolo69
Indianapolis, IN
monsolo69
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
