Pioneer 4800 bs remote wire help
Natebratt21
I have been using the search bar and can’t seem to find a answer to my question, will soon be adding a second amp to my setup for my highs/ mids. But i already have an amp and a micro bypass hooked up to the remote turn on wire. My question is, is this too much for the remote turn on wire/ do i need a relay?/ can i hook a relay up to fit behind my dash? Where would i get the 12v power from? The car is a 2010 Dodge Charger
you really don't need it.. you don't have alot of amps to turn on,but if you want to add relay for piece of mind ..you get the power from the yellow and blue turn on..30 go to yellow,86 to remote turn on 85 to gnd ,87 out to amps
87 to amps and to the bypass?
---------- Post added at 07:11 PM ---------- Previous post was at 07:11 PM ----------
& ohhh okay man thanks!
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
522
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
943
Natebratt21
Natebratt21
Peoria il
ronin1717
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
