Box build for Slammed
here is a better look at the blueprints
so...I guess Im wrong with thinking that the placement of the front baffle would have any internal space loss?
can someone please answer this....Im a bit of a ported enclosure newbie //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pretty much, the tuning of the port is based on the airspace of the box. so if the port was tuned for say 2.5 cubes, and the box is 2.2 cubes, your tuning will be a little higher than expected, and it will also make the subs less efficient.
Well I'm pretty sure that's right //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks for your reply //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
my question was....am I losing internal space due to the baffle being located inside the enclosure instead of being mounted outside?
if the external dimensions are the same as the design, then no you did not lose airspace but yes he admits that there is a build flaw but like a man, he said he would replace it if it breaks.
So everything about the box is the same as the plans i was given except the front baffle was placed between the top and bottom instead of over them.
The overall dimensions are the same and therefore the vol and tuning should be correct. Any clearance issures are the fault of the designer.
Correction, any clearance issues are the fault of the BUILDER, as he is ultimately the one who decided to divert from the original design. The original front panel had taken the clearance issues of the mounting of the subwoofer into account and was to use the remaining connecting panels to account for the strength needed to properly brace the sub. Upon further observations of the enclosure the second time around, I noted that the front panel had been changed and automatically assumed the rest of the plans had been adhered to. Without correct measurements I was unable to determine the actual specifications of the enclosure at that point and proceeded to account for the change of design by subtracting the impeding panels from the original design.
I believe that we can both learn from this miscommunication. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
thanks for the design crzystng
thanks for the enclosure and great communication SPY
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
SPY
SPY
NY
Fusion_FREAK
