Box build for Slammed
um, he didn't:confused: one of the baffles is so he can run a 12" driver if he ever needs to.....
Correct, the box was designed for a 15" sub, but he changes subs almost as often as I do so he asked for a 2nd baffle he could put on to make the box work with a 12" sub
y didint you just make it to where he can insert a 15" round circle that has predrilled holes to fit the 15 and a cut out for a 12" woofer? looks better that way more proffesional I THINK
UPS ruined it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Fuuuuuuuuuuuck, that blows son. Sorry to see that; SPY does good work too //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
wouldn't a 12" vs 15" sub require totally different volume and port area?
well i guess port area stays the same because is pertains to the box but still
Tuning depends on the vol of the enclosure so a different sub or different size sub would only change the vol slightly due to different driver displacement, but I think he is going to mount the sub inverted so it wouldn't change anyting in this case.
Yes it does ****, but we will get it straightened out one way or another and thanks for the complement, I'm not a pro like some others on this forum, but for what I charge I think it's worth it.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
6
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
7
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
11
3K
SPY
SPY
NY
bigbangtheory
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
