Box design for 1 Re audio sxx 10" help
  • 2
I'm trying to build a box for my RE audio sxx 10. I just want to make a simple L port enclosure. It needs to be around 1.25 cu ft and tuned to about 34 hz. I designed one on re box calculator than read this calculator is not accurate. I need help designing this! I tried some other design things but I just can't figure it out so I'm hoping someone else can help me out here. I dont need you to completely design it for me if you dont want i just need help. Please help! Thanks.
(Ps. Dimensions can be fairly big. Only thing is height needs to be around 14 in)
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
538
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
840
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
742
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
Tshaffe
Tshaffe
Tshaffe
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
