Box design Skar VVX-10v2, aeroport?
  • 1
rpd
5
AL
Background: In a hatchback (Honda Fit), going for 30-32hz, up to 1.75 cubes, rear firing sub, port firing dunno yet. Sub will be on 650 RMS (rated RMS is 600w), at 1 ohm. Wanting to try aeroport mainly just for the fun of it, but it's advantages do line up nicely with my goals. I have my maximum outer dimensions figured out, but seeing what the modelling might dictate that before committing to any of them. It will should end up being less than my maximum.
Using WinISD Pro, I haven't found any combination of box volume and port configuration that gives even a borderline rear port air velocity figure, even 2 4" ports give over 80 ft/s. Singles and multiples of 2" - 4", nothing works out. I input both Pe as 600w, Signal: system input power as 650w. I understand that the program can't account for flared ends, but surely it wouldn't make that much of a difference.
Is there a problem with the way I put in the Pe and signal parameters, or should I just give up on an aeroport for this box? Also, I don't want any of the port sticking out, just no.
Sub T/S: Skar Audio VVX-10v2 600 Watt RMS 10" Subwoofer
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
542
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
851
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
748
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
rpd
rpd
AL
rpd
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
