Box design
  • 3
Ok thank you
:thumbsup:Welcome.. you may even google up some enclosures built for that sub to get an Idea of which will work best for your vehicle that others have experienced with and gained better results than the recommended site built enclosures that are basicly generic, as most of us break the rules and experiment outside the box and gain better results and maximize towards better performance
I need a ported box design for a hds315 (0.13 cu ft displacement) running at 1600 watts. What would be a good net volume as well as area and placement of port?
If you list your vehicle & actual space available, actual amplifier (brand/load) and goals (LOWS, daily low tuned, daily high tuned or SPL)... you might get some specific help... that's too vague of a question to answer without a vague response...
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
635
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
947
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
821
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
Dudebro241
Dudebro241
Pa
shredder2
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
