Box for HT sub?
  • 2
miker
Wayzata, MN
I'm assuming a box for a home audio application is much different than that of a car.
anywhere I can get info on how to design on for home audio use? Or someone here who could design one?
I use my HT for Movies/Games/Music. In that order. music being a very insignificant part of its use.
Generally larger and tuned lower is what works best to give you an extended bass shelf(EBS) down to 20hz and possibly lower with the right setup. What sub are you using?
Well all I currently have to use is a 10" lanzar MAX sub Lanzar spec., which will hopefully be better than the crappy ONKYO sub that came with my system. It will be powered by a 290watt amp.
I'm going to have some time over winter break, so I wanted to make this my project for the month.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
A little DAP will do ya, drill, feed & seal, done.
712
miker
miker
Wayzata, MN
miker
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
