Box help...8 Soundqubed HDC4 18s
I need some help with a quite extreme box.
So far, due to space limitations, i am thinking 2 boxes like this on top of each other.(image link)
Is this a good type of box for music or spl? It will be loud either way, i know, but what are your other thoughts on the box? I need box tuned in the 30s for music.
By the way I am working with a large crew cab tundra. The maximum box size is approximately...42" deep,62" wide, and 47" tall.
If this isnt a good box, given my needs, then what would you suggest?
Lots of questions (sorry) but please respond, even if you only answer one.
(B4 this gets started, dont ask "who needs 8 18s?" Because i do LOL)
Looks to me like you won't have near enough volume to really do 8 18's properly. Your "max space" is about 70 cubic feet. Less 20 cube (10 sheets of 3/4 wood) probably a low estimate, and you're at 50, eat up enough for an adequate port and you're down to under 40. I'd say you should reconsider going with only 4 18s or 6-8 15s.
Really though if you had 8 18's even in too small sealed box and threw enough power at it it would be very loud, but you're going to be using way more equipment than necessary to get to the same place.
I don't think yall are talking about this sub. Yes your right he does have more airspace, but that dosent mean i can't fit them. Not all 18s take up lots of air.
According to this (HDC3 & HDC4 Optimum Enclosure Size - Subwoofers / Enclosures - SMD Forum) post by AMI Customs since I am running 4k watts rms i only need 5.5 cubes per sub and 93 sq. In. Port per sub. If I tune in 35-38hz range this is definatly possible.
If you are about to ask where my electrical and amps are going, i am putting them in the bed.
You misjudge the amount of bracing and doubling up on layers to keep a box with 8 18s from falling apart especially on the low lows I already know what the hdc4s are and what they need to get loud. I saw that thread right when it first came out...... Plain and simple you still dont have enough space. 6 hdc4 18s would be better and louder in the amount of space you have.
No box flex = higher dbs
No to mention batteries and amps. You dont nearly have enough room as you think man. People always misjudge and fk up on their builds.
Hey, if you know best already why even ask? Buy some wood and start building, let us know how this pans out for you.
Ok, better safe than sorry. What do yall think about 8 HDC4 15s with 4k input. According to that link above, for an spl build they need 3.75 cubes a piece 17 sq in port per cube. It also says tuning 35-38hz. This sounds possible with my space.
Sorry man, didnt mean to disrespect you or anything. As you can see now ive switched to 8 15s
If you're willing to take any advice, build the top back and sides then see how much space you really have left over after it's strong enough to take a bomb blast. As Jeff said, you probably don't have nearly as much space as you think you do (we have all been there) and cramming too much cone area in too small a box will give you poor results.
This box was built for 9 15's and it's a very large box in a big van. Even with 3 subs blown and their holes plugged up it does the same numbers on the meter with only 6 subs. Also worth mentioning, that van has solid rubber armored truck tires and a LOT of custom suspension work done so that it can actually drive.
Cramming too much cone area in too little space might look impressive but performance will suffer and you're wasting money on equipment you didn't need.
There's some big dogs in Texas, if you're serious about this, you would do well to meet up with some of those local guys that have done big builds before and get some help and advice. **** looks cool on youtube, but I think you might be way underestimating what you're getting into here.
4 15s in big box doing a 160db is way more impressive then 8 18s doing a 160db.
From the way your posting I think u should start smaller and work your way up..we all didn't just start out and spend $20,000-$30,000 on a proper install..
alts
Batts
Wire
Lugs
Subs
Amps
Wood
Not trying to discourage you but I hope you have deep pockets and know what your doing because if you have a b pillar build this size and don't do 60s+ these days your a failure.
Highly recommended to build a shell first then your baffle and port. Once that is built you will need to see how much area is left to work with after a good amount of port is used. If you want crazy loud id go with as many 12's will fit with what space you have available.
Ok thanks for yalls help so far. I need to rethink this whole thing and start from scratch. But to clear some stuff up, this is not my first time with car audio, right now i am running 2 15s on 3k doing up to 150db. I do not have enough money to work up to large wall builds, so i have to make a big leap to hit upper 150s. I hope this is not too much of a leap, but so far everyone seems to be helpful.
It sounds like i need to build a shell then find exactly how much airspace i have.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
718
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
Will.......
Fort Worth, Tx
hispls
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
