Box help for 8 12s
  • 1
bad03ranger
Get Some *****
I picked up 8 CHEAP dual SD12 subs and wanted to do a stupid box in my 02 explorer, just a simple sealed enclosure, my question is can I leave this as a shared enclosure for all 8 subs or not? I'm not looking to set any records or win comps but just say I got 8 12s but I still want it to sound decent
the box will be:
W-40
H-15
D-35
10 cu ft
I will be running them @ 2ohm per channel off a powerbass asa600.4 100w to each sub
added: what about this same setup ported?? Would 10 3"x13" ports do any good w/o separating the enclosure into different chambers?
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
839
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
bad03ranger
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
