box help
  • 2
cd6551
Corydon, IN
ive decided that im going to have 2 image dynamics id8v.3s in my back deck ported. I will have the subs exposed from the inside (like a normal rear fill speaker in the deck) and the box is going to extend down into the trunk. My question is should I have the port on the same surface as the subs or firing down into the trunk? The box will be a 1.8 cubic foot ported to 30 hz i think. let me know what the difference will be if any
Never seen this done before Id have to say, but what I think I would try first is the port thru the rear deck, and the subs facing into the trunk...
Dunno... You never REALLY know with the new designs till you try.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
881
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
cd6551
cd6551
Corydon, IN
cd6551
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
