box help!!!!
  • 3
hidenboom
i have a 85 dodge truck with bucket seats. I have no more room behind them do to the box that holds 2 - 12's I now i need a little over 1 qubic foot of air space, but how and were would the best place for me to move them to for more room in the back of the seats? thx
Yep, I've seen many stock center consoles with a hole in the back housing an 8" or 10" Kicker L5/L7 driver. I have done center consoles in regular cab trucks with buckets that go straight from the dash right to the back of the cab, housing 2-4 10/12" drivers.
You could also do a "cut-though" box. The box would be in the bed and the drivers would be facing into the cab.
- Steve
the center concole would be great but can i still get the propper square inch airflow and still have the punch that i have now? I need to put the amp and the sterio in there also if at all possiable!
Get the measurements of your center console and figure out the cu.ft. Or build your own custom one based on the sub(s) specs.
- Steve
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
745
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
hidenboom
hidenboom
Mesa,AZ
ss3079
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
