Box Recommendations and Request for Quote: JL 12w3v3 in 2011 Hyundai Sonata Hybri
  • 2
walesmd
I've been a lurker on these forums for awhile and I've finally decided to register, get involved, and ultimately get a little help. I've been looking for a sealed enclosure (sale or blueprints) that would support a JL 12w3v3 (2 Ohm; JL 500/1 pushing it).
The vehicle is my daily driver, 2011 Hyundai Sonata Hybrid, and I'm aiming for tight, clean bass that hits the lower end and simply sounds great. I wouldn't mind being able to turn some heads from time to time but it's not really the goal. I mainly listen to electronic and rap with a bit of rock mixed in.
I've seen JL's Preloaded StealthBox and something of that nature would be absolutely perfect as long as it met JL's specs for volume of 1.25 cu ft (I'm interested in hearing others experience with this size as well). Unfortunately that box sits on the passenger side which is significantly different on the hybrid model as that is where our auxiliary battery sits. I believe a mirror of this design, bringing it to the driver side, would work perfectly - I don't believe that portion of the trunk had changed. (abt.com/product/53053/JL-Audio-94500.html - new account, had to remove link)
I've only seen one other design, specifically geared towards the Sonata, in which the enclosure takes the width of the vehicle and is pushed against the rear seats (supercrewsound.com/jeff.html - had to remove BBTag due to new account). Once again, I believe the hybrid alterations prevent me from using this box as I have seen it although a similar one could be possible.
If anyone has links to boxes they recommend I'd love to check them out. Also, I know there are quite a few well respected fabricaters here; I would absolutely love to discuss this further with you and provide what you need in order to get a quote for an enclosure built and shipped. I've yet to build a trusting relationship with local shops and plan to have this installation done before that would be possible, so I'm leaning on the public's well respected opinion of you all here. If any happen to be in the San Antonio area, or have professional contacts here, that would prove useful as well.
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
No sense in arguing, the software has helped me do just that, many, many times. A smaller box can be tuned to the same lower frequency in this...
20
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
192
walesmd
walesmd
San Antonio, TX
Dtrom
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
