box tuning
  • 3
wp7456
orlando
I am looking at getting a 12" FI Q and was wondering if I tuned it to 32 hz., how bad would the drop off be for below 32 hz? Would it be too severe to hear notes like the 27 hz. note in "Put On". I would be using an 08zx750.1 if that matters.
If I wanted to tune the box to say, 27 hz., would my higher frequencies suffer more than if it was tuned to 32 hz? I also have a SSF in the amp that is set to 25 hz. Thanks guys.
The lows will be sexy and you will be just fine on the highs. im pretty sure Fi recommends 32Hz. and thats about where you want it. you will hit 27hz like a champ and you'll hit 45 like a champ too.
32hz will be perfect. below 30hz you really dont get much use on music. 32hz will give you all the lows you need and the higher notes will still be excellent. with 27hz youll be losing out on the higher notes for not much noticeable gain on the low end. youll be able to get 3-5 hertz below the tuning freq before the ssf needs to cut off the signal. so at 32Hz you're still getting 30hz and just a lil below.
ludacris - blue berry yum yums is really low, but still above 30hz.
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
5
Gents I appreciate your knowledge and you sharing it. This is helpful in my understanding.
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
683
wp7456
wp7456
orlando
wp7456
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
