Box tuning
  • 4
Depends on listening habits. 40 is a little high unless you almost exclusively listen to rock, alternative etc.
I find 35hz to be a good middle ground for a mix of genres
I have 2 planet audio ac12d 2 ohms.will a box tuned @ 40 hz sound good for these subs
yeah if u mostly listen to rap or real low bass u need to be 35hz or lower (also if your amp has a ss filter set it at 35hz or so on current box)
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
Gents I appreciate your knowledge and you sharing it. This is helpful in my understanding.
134
Brick20
Brick20
Chattanooga
Brick20
    May 18, 2024
    May 18, 2024
