Bridging an amp to one sub
  • 4
You can bridge each side but you can't turn it into a mono amp. I have seen guys in the past bridge each side and run one side to each voice coil on a dvc sub. Would be best with 2 subs imo, as its not advised to run 2 different channels into 1 speaker. But I have seen it done.
Soundstream Reference 644s
The old blue ones from back when Soundstream was a premium brand? I'd advise against. That would be a fine amp for mids and highs (though it's probably nearing the end of it's life or the point where you'll need to have some components replaced to keep it going) but with the cost size and efficiency of modern monoblock amplifiers there's absolutely no reason to over-work one of those old dinosaurs on sub duty.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
976
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
6
197
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
446
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
391
roccodiesel
CarAudio.com Newbie
roccodiesel
Rancho Murieta
audiobaun
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
