SOLD C&D Technologies Batteries, 134AH, $110 plus ship
basscort2009
Banned
7,052
dallas tx
ok so i have been steered to make a new thread. heres the old thread for referance.
http://www.caraudio.com/forum/showthread.php?t=411192
SPECS:
C&D Technologies Dynasty High Rate Series UPS12-475FR
Valve Regulated Lead Acid Battery
12V 134AH @ 20 Hr. Rate
12V 475WPC @ 15 min. rate, 1.67vpc
Features
10 year design life @ 25 degree C
2 year replacement Warranty
Absorbent Glass Mat Technology, AGM
Flame Retardent Polypropylene case
No restrictions for Ground/Air Transport, non spillable battery
Specifications
Dimensions = 13.57"L x 6.76"W x 10.93"H
Weight = 100lbs
hey, what kind of connectors would be best for these batts?
the copper ones in the picture i have found to be the best. 100% copper and allen hed key on top to bolt any wire down. no crimping involved, way better and way easier than crimps
I found a couple at a local Home Depot/Lowes, but not all carry them. The 4/0 connectors fit perfectly. I solder these connectors to the wire as well as using the set screw, so I have a nice big mass of solder and copper. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
230
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
432
basscort2009
Banned
basscort2009
dallas tx
basebalz13
Decebal
    Jun 10, 2024
