C2 Audio Team Edition 1K -- Come and Get Them!
C2 Audio
The Official C2 Audio Team 1K 12" Group Buy has Started! We are Only offering this Group Buy for a few weeks or until all 200 woofers are sold and then the Group Buy is Over! Build time and delivery is only about 6 weeks on this once the Group buy closes. This woofer is Only Available through this Group Buy and will register you as a C2 Audio Team member.
Features:
The New Team 1k 12" Woofer is by far the best woofers ever to be available at this price and is only available here on this official Group Buy. With your purchase in this group buy you will be registered as a C2 Audio Team member and will gain access to all Team member perks including drop in recones, swag and other team member exclusives. An email will be sent out shortly after your purchase so we can get you registered.
The Team 1K woofer features More than you would ever expect from a woofer at this price point. C2 Audio has addressed every single part that can fail under High Temps from extended High Power use and than over built them. This woofer uses A High Wound (50 mm) 4 layer 3" High Temp Ultra lite weight CCA Voice Coil, Large Double Stacked Magnets , Dual High Current Flat Woven Tinsel Leads per terminal, Bolt Down Spider Pack using Four 7.25" Black Nomex Spiders, Dual Vented Back Plate to assist in fast High Temp cooling, Dual Stitched surround and Lots of X-Max!
High temp Thermal Meltdown with Magnet shifting is a thing of the Past with the Team 1K. This woofer use a Bolt down motor system in addition to our extended temp glue. The bolts run through the entire motor to attach the Basket, Top Plate, Magnet and back plate as 1 part. Sure this takes time cost more to build.... But the Team 1K is designed using the highest grade parts possible to ensure your woofer last under extreme conditions.
Your Production woofer will have the C2 Audio Flat Black Basket and the Exclusive Team C2 Audio 1K Logo Dustcap.
Specifications:
12" Team 1K Subwoofer
1000 Watts RMS
Available in Dual 1 Ohm and Dual 2 Ohm
High Wound (50 mm) 4 Layer 3" CCA Voice Coil
Dual High Current Flat Woven Tinsel Leads per Lead
Bolt Down Quad Spider Pack
Dual Stitched Non Pressed Paper Cone with High Roll Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.50 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hz
T/S Parameters:
12" Team 1K Dual 1 Ohm
FS: 38.625 Hz
VAS: 34.1188
QES: .468
QMS:
QTS: .413
Le: mH
BL: 24.505
MMS: g
SENS: 87.63 db
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 7"
AVAILABLE AT LINK BELOW!!!
http://www.carstereogiant.com/product-p/team-1k-12-gb.htm
C2 Audio
C2 Audio
Youngstown, OH
babsuhl81
Decebal
    Jun 10, 2024
