CAB 2000.1 Question
  • 4
At 2 ohm it should do 1300 fairly efficient and that should be fine. The Fox Acoustic Dodge Ram box is already a little small to start with at 1.55 per side
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
giltyler
giltyler
DFW METROPLEX
giltyler
