Can I use just 1 channel of this 2 channel amp, unbridged?
nohandbrake
Hi,
Recently purchased a used amp and sub ($45 total!) and I'm wondering the best way to run them together. I now see that they aren't great matches for each other, but can I use just 1 channel of this 2 channel amp, unbridged (300 Watts x 2 channels @ 2 ohms)? Is there any danger to the sub or amp doing this?
I am planning on using the high level speaker inputs on the amp, and wiring the single 4-ohm dvc sub in parallel (amp sees 2-ohms right?). 2012 Honda Fit Sport - just looking for some additional bass inside the car, speakers and HU stock. Thanks for your advice!
Amp - Dual XPR522
Power Output:
150 Watts x 2 channels @ 4 ohms
600 Watts x 1 channel @ 4 ohms (bridged)
Peak Music Power Output: 600 Watts @ 4 ohms
Sub - Polk Momo
MM2104DVC
10" 4-ohm subwoofer
Dual Voice Coils
power handling: 50-300 watts RMS
peak power handling: 600 watts
Wire the subwoofer to 8 ohms and bridge the two channels. "300" watts.
Or
Wire the subwoofer to 2 ohms and run on one channel. "300" watts.
You MIGHT get 100 watts RMS wired either way.
The 8 ohm option will be overall better for your amp because running that one channel at 2 ohms will be sort of maxing it out, running it bridged at 8 ohms will be less stressful, probably less distortion overall, things of that nature.
411
493
10
864
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
899
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
nohandbrake
nohandbrake
Santa Cruz, CA
Buck
