can you blow a speaker from too little power? only smart people please
you can over power any speaker / sub with a clean signal / un clipped and break it.
parts can only handle what they are designed to - maby a bit more - but if you are playing a 300w rated rms subwoofer off a sundown 3000w amp and feeding it its full streingth with clean power and clean signal - id bet that little 300w rated sub would simply pop dead in a matter of seconds - if not on the first full stroke out.
A clipped signal has no effect on cooling. The sub is still moving continuously unless it bottoms out at which point you have other problems.
Not trying to be argumentative, but with a clipped signal, the sub doesn't move for a short period of time at the peaks and dips of the waves where they are cut off. Cooling isn't effective if the sub isn't moving. So while the sub stay motionless for whatever amount of time it does (depending on the amount of clipping), that would also add extra heat. Even though it might be a very short amount of time the sub stays "motionless", over time it would all add up, I would think.
very good answers you guys...granted i understand the issue and question at hand i just wanted a little bit more in depth answer. thanks you guys
Doesn't work that way. As long as voltage is applied and current is flowing through the coil it is applying force to the coil moving it away from center. The cone continues to move out until either the coil force is removed or reverses direction, the coil force is insufficient to overcome the suspension and loading forces or the sub hits a mechanical limit. Just because the wave form is clipped doesn't mean that the sub movement looks like the waveform.
TL;DR... the answer is USUALLY NO.
A subwoofer can't be blown with too little power. HOWEVER the sub can still overheat if that particular amplifier happens to be able to output enough current(clipped signal or not) to overheat the coil.
It's really f'ed up though because I've came very close to blowing a Kicker Comp 12 subwoofer with a "1000 watt" Pyramid that really only did about 150 watts RMS. The sub didn't smell when I left it at that volume(the amp has a clipping indicator), but when I push the amp into hard clipping(it is still outputting more power even though it's clipped) the sub started to smell and got worse and worse(the clipping light is brightly lit constantly at this point), smoke started to pour out of the port too.
An amp rated at 100 watts RMS @ 0.09% THD(total harmonic distortion) may output as much as 200+ watts RMS @ 10% THD, so "can a sub blow out from too little power" is too broad of a question without knowing the brand and model.
I guess when in doubt buy a DDZ, you might get a prize if you manage to blow a sub like that.
I didnt read any posts other than the original.
Michaellane, do this.
Buy a cheap sub that you know can take its rated power cleanly. Then get an amp rated half that. You need 400 RMS at 4 ohm, so get 200 RMS at 4 ohm. Then turn the gain all the way up to the max and tell me if it blows and you will have your answer.
^^^If you're fully clipping the amp and it is putting out 200W then you aren't sending 100W to the sub regardless of the amp rating. You're sending more than the sub can handle thermally. Period. Whether you're doing it with a big amp or clipping the **** out of a smaller amp the fact remains that you have to exceed a sub limit to blow it. If you are genuinely sending the sub less than it can handle it won't blow, barring a defect of some sort.
That still isn't an answer to his question. That would be sending rated or more power to the sub, not blowing it with less power than rated.
So your saying that a 200 @ 4 ohm amp will do 400 with the gain turned all the way up.
If a sub is rated at 400 RMS. Id be willing to be that 300 RMS clipped will blow it before 500 RMS Clean does.
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
3K
I mixed a trap beat and that christmas song 'silent night' together, then screwed it, bass boosted it, and added a non-stop 25hz note, then put in...
57
5K
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
577
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
484
michaellane
michaellane
tx
Skip01
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
