Can't find a good enclosure frequency response curve calculator
  • 3
tb30570
The last time I build a subwoofer enclosure (for home not audio not car), I was using a website where I could input the Thiele Small parameters, enclosure size, port dimensions of my choosing and it the website would plot a frequency response curve. It was really helpful for not only designing an enclosure but for choosing which subwoofer to purchase based on what output characteristics I was interested in.
I tried searching for the same website I used last time and have had no luck. I did find some websites, but they are pretty limited.
This is the only calculator I could find that plots a curve. It doesn't allow an infinitely variable input of enclosure size for a ported enclosure. It gives you three options (small/medium/large). The horizontal axis is labeled very coarsely too (10hz,100hz,1000hz). I'd rather see 10hz increments from 10hz to 100hz.
Subwoofer Box Enclosure Design Calculator - Sealed Ported Bandpass Closed Vented
All the other calculators I found don't plot a frequency curve. They simply output f3 and fb which isn't nearly as meaningful to me as a plotted curve.
Is there a better website out there or is this information only available on licensed software?
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
880
Dayton would be a really nice choice as well as the SQL. I would look at a R. Sounds sub too https://www.resilientsounds.com/product-page/gold-15...
7
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
8
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
8
tb30570
tb30570
North Dakota
Papermaker85
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
