Kicker
Icecube91
I just saw Kicker some new products and was wondering about 3 of there subs from there lineup. The CVX, Comp Q, and new L7s. I'm thinking about putting either 2 10s or 2 12s and need to know which you guys will hit the hardest. Might actually take the L7s out because the box might be too big. The real question is Comp Q or the CVX?
two 12s will hit harder than 2 10s...go with the CVX's
The CVX are rated 750RMS and the Comp Q are rated 800RMS so should the Comp Q be louder and plus there new for 2016 while the CVX are older
Nothing from kicker. If you are looking for the loudest it'll cost you since US to canada shipping is gonna be rough and US made woofers are pretty costly vs kicker's china stuff.
I agree. I'm running a 12" cvx on a clean 1500w. It handles it just fine, but I had a diamond d3 and it sounded tons better. I don't know how to explain it, but the diamond just seemed smoother throughout the frequency range. The cvx is extremely tight sounding.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
915
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Icecube91
Icecube91
Vancouver, BC
xr650jkallen
