Cant make my mind up yall help me decide...
  • 3
pcchris
2 15s in a 4th order walled in 2 door coupe vs 4 15s flat wall ported
4th order:
pros:
efficiency
less subs to recone
less money spent on subs
Cons:
cant see subs
flat wall:
Pros:
More cone area
More play time
can see the subs :) (along with vagrants and parking lot thieves) :-/
cons:
need more power
more money on subs
more things to recone
has any one been in a similar situation? I cant pull the trigger... i have the money and need to get building ...but don't want to be disappointed running just 2 15s over a quad setup ....although both will be walls so should be loud regardless
Man. We all have had our share of good and bad on here. Ive deff. had my share for sure.. LOL. It all works out in the long run. Excellent to hear...
9
653
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
8
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
We still need to know what amp is having the issue, make and model. Some mono amps only have 1 preamp input and the other is a output.
7
pcchris
pcchris
Houston Tx
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
