Both amps stopped working help
  • 2
I was driving and both front stage, sub amp and speakers ran off deck stopped working at the same time system wasn't turned up even half way. There is no power at the amps fuse are good when I disconnected the batter and hooked back up speakers ran off deck started working again but still no power at the amps any ideas on a fix or even just what might be wrong would be greatly appreciated
When you do find a new Ground spot look for something existing that is tapped. If nothing like that is available make sure you cleanthe area to...
13
3K
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
331
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Quinn88
Quinn88
Eugene, Oregon
mylows10
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
