cant post in the WTT section
  • 3
Post up a couple pics in the main add then post a second time with more.
The better option would be to stick around the forum and put some time in. Assuming you contribute to the forum this would get you past the limitation you are having an issue with now.
Man. We all have had our share of good and bad on here. Ive deff. had my share for sure.. LOL. It all works out in the long run. Excellent to hear...
9
379
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
8
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
We still need to know what amp is having the issue, make and model. Some mono amps only have 1 preamp input and the other is a output.
7
Ilovelows1234
Ilovelows1234
Cleveland,Oh
MikeofTulsa
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
