Captcha is not working
  • 3
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
6
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
8
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
jlh0989
jlh0989
st. louis
adulbrich
Dylan27
    May 19, 2024
Dylan27
    May 18, 2024
