Car Audio for Street/Strip car
Small update. I don't drive the car in the winter, but I was messing with it the other day and set the HPF to 80hz and it cleaned up the distortion significantly.
I also ordered a an amp, a used Kenwood KAC-M3004, which I will install eventually (it's too friggin' cold right now)
I appreciate the help, and will update the results of the amp install when the weather gets warmer.
Nice compact amp. Should work for you.
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
617
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
417
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
941
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
619
chuckwolfe4k
CarAudio.com Newbie
chuckwolfe4k
Philadelphia
audiobaun
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
