21 Gladiator, New System, Quality Issues
  • 2
SSpiro
.:] Audiophile [:.
Just installed 5 channel amp (Kenwood XR900-5), subs (JL CP208LG-W3V3), and a PAC AmpPro. I have the upgraded factory 8.4 head unit with factory alpines, factory amplified sub. I planned on using factory speakers for now. My understanding is that the PAC bypasses the sub and amp
I'm getting some major crackling and distortion when I turn the volume mid way or so and have to turn the gains way down to avoid. They're currently at 1/4 or so. Unfortunately it means my min volume is around 18 on the deck, and when I get to 24 and beyond it sounds horrible. The adjustment knob for the PAC is in the middle. If I turn it down it turns down the subs. I've tested with the knob all the way down but still have the same issues.
Is this a stock speaker problem? Amppro issue? Sound quality is great in the narrow window but volume is low due to turned down gains. 😞where do I start?
Quick update. PAC recommended that i replace the amppro and that it might be defective. Did that today and same result. so its either source or the amp.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
471
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
909
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
943
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
SSpiro
.:] Audiophile [:.
SSpiro
Atlanta, GA
1aespinoza
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
