Car audio stores in the Boston area?
  • 4
deburn
I need someone to get a CD that's stuck in my car CD changer which is in the front console, and also run a USB/line in for my iphone - and maybe install a HD radio tuner at the same time.
The store that is recommended in the Mass forum is high end and charges at least 2 hours worth just to get the CD out at 100 bucks an hour.
I dont need high-end - any suggestions? Thanks
Honestly, I'd check on yelp.com, but if you're willing to travel about 40 minutes you can go to Lowell or Lawrence and get stuff done for pretty cheap. Just get out of the city and you're already looking at spending less.
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
297
16
730
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
458
deburn
deburn
Cambridge
CL1CKCLACK
SlugButter
    May 4, 2024
slater
    May 2, 2024
