Car speakers suddenly stopped working one day but stereo still turns on???
  • 3
jakej1996
Mt
I got in my car one day and the car stereo still turned on but no sound from any speakers. Not even static, I have a 1996 Dodge Intrepid with the infinity sound system. Do I have to replace the stock infinity amp orrrr?
find ur stereo fuse and pull it (with vehicle off of coarse) and then put it back in and turn ur car on and see if that works, my mothers car does that sometimes, everything turns on but no sound, if that does not work and assuming this is all stock then u may need to replace, but its odd that they would both go out at the same time, it could possible be the head unit, but pull the fuse 1st so u can get a reset and see if that works.
When I bought the car it came with a pioneer head unit with stock speakers. It worked fine, I hopped in one day and the unit powered up but no sound or static and it couldn't find any radio stations, am or fm. checked the fuse, it was good. Even replaced it and still nothing. I replaced the deck with a used dual that I knew worked. Still same problem, Its getting really frustrating.
that sounds like a problem with your antenna/ant wires.
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
If you feel that the factory speakers in your car produce a dull sound lacking deep bass and clear, crisp highs, and if you don't want to spend a...
Now you want to know how to do this on your own car? On certain cars that allows you to use head units that are high power, you'll be bridging...
8
jakej1996
jakej1996
Mt
loudenuff
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
