Simplified Series (Part 1): Key Considerations for Upgrading and Replacing Factory Car Speakers
  • 1
David Anderson
CarAudio.com Newbie
If you feel that the factory speakers in your car produce a dull sound lacking deep bass and clear, crisp highs, and if you don't want to spend a lot of money or lack the technical expertise to upgrade your entire car audio system, then choosing to replace the speakers with ones that match the original size specifications would be your best option.
When you search for car speakers online, you'll come across a wide range of choices, which can be overwhelming. The purpose of this article is to help novice enthusiasts understand speaker specifications and select the most suitable speakers within a limited budget.
Before you start browsing for speakers online, you need to determine the size of your factory speakers. Common car speakers come in various sizes, including 4 inches, 4 inches x 6 inches, 5-1/4 inches, 5 inches x 7 inches, 6-1/2 inches, 6-3/4 inches, 6 inches x 9 inches, and 7 inches x 10 inches. Among them, 6-1/2 inches, 6-3/4 inches, and 6 inches x 9 inches are the most common sizes. Typically, the original speakers are installed inside the car doors, and you can simply remove the door trim panel to access the speakers, measure their size, and choose the appropriate size of car speakers. You can also search online for your car's brand, year, and model to determine the speaker size.
Once you understand the size of your car speakers, you can begin searching online for speakers that match your size, such as 6.5-inch car speakers. You'll find a variety of 6.5-inch car speakers. Let's now explore the various headings and specifications related to speakers together.
Taking the example of the Cadence IQ653 found on Amazon in Figure 1, the product title is "Cadence IQ653 6.5 Inch 3-Way Full Range Car Speakers, 250 Watt Peak Power, 4Ohm, 100 Watt RMS, 1 Inch Voice Coil Coaxial System Car Audio Loudspeakers, Pair, Grill Included." This product thoughtfully includes all specifications in the title. Additionally, the "About this item" section provides a complete set of specifications, including: "Sold as a Pair. Size: 6.5in. RMS/MAX power: 50W/125W (Each). Frequency Response: 70 Hz – 20k Hz. SPL at 1W / 1m: 89dB. Magnet: 16 oz. System Impedance: 4ohm. Mounting Depth: 2.13 in." I will discuss these specifications in detail to assist beginners in selecting suitable speakers for their cars in a clearer and more professional manner.
First, let's examine the important information in the title section:
• Cadence IQ653: This represents the brand and model.
• 6.5 inch: This part indicates the size of the car speakers. Before choosing the speakers you want to upgrade, you need to determine the speaker size that fits your car. The size of your car speakers needs to match the size of the upgrade speakers you purchase to avoid installation issues caused by being too small or too large.
• 3-Way Full Range: This indicates that this speaker is a 3-way full-range speaker, which means it consists of three drivers that produce low, mid, and high frequencies, combining to create a full-range speaker. Generally, the human ear can hear frequencies ranging from 20Hz to 20kHz, although this range narrows gradually with age.
• 250 Watts Peak Power: This value represents the maximum power that the speaker can handle for very short durations. In other words, if your music suddenly produces a loud, intense sound, the speaker can handle it without being damaged. Peak power is not the primary value to consider when selecting speakers but can give you a rough idea of their capability.
• 4Ohm: This indicates the speaker's impedance, which is measured in ohms. Impedance represents the speaker's resistance to electrical current. Most car speakers have an impedance of 4 ohms, and this value must match the impedance of your car's audio system to ensure proper compatibility.
• 100 Watt RMS: RMS stands for Root Mean Square, which represents the average continuous power that a speaker can handle without being damaged. When comparing speaker power, RMS is a more important value to consider than peak power. The RMS value is an indicator of how much power the speaker can continuously handle for an extended period. In this case, each speaker can handle 100 watts of continuous power.
• 1 Inch Voice Coil Coaxial System: This part indicates that the speaker has a 1-inch voice coil, and it is a coaxial speaker system. The voice coil is an important component of the speaker that generates the sound. The coaxial system means that the speaker's drivers (woofer, mid-range, and tweeter) are aligned and integrated into one unit.
• Car Audio Loudspeakers: This section confirms that these speakers are designed for car audio applications.
• Pair: This indicates that the product includes two speakers.
• Grill Included: This specifies that the product includes speaker grilles, which are protective covers for the speakers.
Now let's move on to the specifications provided in the "About this item" section:
• Sold as a Pair: This reiterates that the product includes two speakers.
• Size: 6.5in: This indicates the size of the speakers, which is 6.5 inches.
• RMS/MAX power: 50W/125W (Each): This value represents the RMS and peak power handling of each speaker. Each speaker can handle 50 watts of continuous power (RMS) and up to 125 watts of peak power.
• Frequency Response: 70 Hz – 20k Hz: This range represents the frequencies that the speakers can reproduce. The lower value, 70Hz, is the lower limit of the bass frequencies, while the higher value, 20kHz, is the upper limit of the treble frequencies. A wider frequency response range indicates that the speaker can reproduce a broader range of frequencies.
• SPL at 1W / 1m: 89dB: SPL stands for Sound Pressure Level and represents the loudness or volume of the speaker. This value indicates the speaker's efficiency in converting electrical power into sound. Higher values indicate higher efficiency, meaning the speaker can produce louder sound with less power.
• Magnet: 16 oz: This value represents the size of the speaker's magnet. A larger magnet can help produce more accurate and powerful bass.
• System Impedance: 4ohm: This reiterates the speaker's impedance value, which is 4 ohms.
• Mounting Depth: 2.13 in: This value indicates the depth required for the speakers to be properly installed in the car. It is important to check whether the speakers' mounting depth matches the available space in your car's speaker mounting locations.
By understanding these specifications, you can narrow down your choices based on your preferences and budget. Consider factors such as speaker size, power handling, frequency response, efficiency, and mounting depth to find the most suitable speakers for your car.
Remember that upgrading your car speakers alone may not dramatically improve the overall audio quality if other components in your car audio system, such as the head unit or amplifier, are not up to par. However, replacing factory speakers with better ones can still noticeably enhance your listening experience.
I have a pair of telza audio 12" subs for sale great condition never ran over the 1k RMS rating. I'm willing to ship just need to know a area so I...
You can stream videos off of youtube. There are some videos of Japan, and some nature videos that are awesome to watch, and show off the...
5
213
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
6
David Anderson
CarAudio.com Newbie
David Anderson
chicago
David Anderson
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
