cda-9855
you can set your time alignment, EQ and crossover and then burn the settings on to a cd that you put into your headunit.
the headunit reads it and uses the settings you put together online.
I used it on mine to set up the greeting message, but that's about it so far. Will probably mess with Time Correction and other settings after the system is all in.
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
914
That’s really helpful, thanks! I’ll keep digging and see what I can find online :)
I'm hoping to find someone who might be able to repair this head unit. The faceplate doesn't slide out at all.
VC1978
my name is vince
VC1978
Dover, NH
darkknight
    May 20, 2024
    May 20, 2024
