check box specs
Use your brain.
Subtract all displacment from the box size. It is that easy. If you need a bigger box increase the dimmensions. It's not really rocket science.
ok now if this one isn't right I'm gonna //content.invisioncic.com/y282845/emoticons/wallbash.gif.1310150c49dd52e0fbe1813a0681e5c3.gif now we got port area=45^2 internal vol=3.5^3 tuning frequency=28hz //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif :uhoh:
went over math again and I think internal depth should be 20" and port wall 1 should be 17" and port wall 2 should be 15.6"
Almost there //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you have the internal depth to be 20, like you mentioned (but wasn't in the pic) then you're looking at right around 3.5 cubes at 28Hz (a little less, like 3.45ish, no biggie). That's with EXTERNAL dimensions being 21.5 x 31 x 15.
The only other issue I saw with it is that your port area is wrong...it's really 40.5 square inches because you have to account for wood on the top and bottom (3 x 13.5).
I didn't check the port walls, but I assume they're correct as long as you get a port length of 34.5" which is what I am getting.
oh I get it I think I just got all screwed up because you but the 21.5 before the 31 in the dimensions //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
the_flatlander
the_flatlander
Wisconsin
the_flatlander
maylar
    Jun 2, 2024
    Jun 1, 2024
