Checkout this interesting OEM amp from a Volvo C70
  • 2
Wingman0121
Alpine Dynaudio 100W RMSX4 4 Ohms 4 Channel Amplifier Volvo C70 | eBay
The amp has screw terminals (is this a thing now?) just like a normal amplifier except it has a DIN plug for the RCAs and remote turn-on. It says 100 watts x 4 and a fixed 20Hz subsonic filter so it's set up for full range. It looks well-built and it's made in Korea.
Do OEM amps have to go through a tougher quality check since it's built to last alongside with the car? This could be a sleeper if it lives up to the name.
looks like my good old MRV-F505.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
710
Here is a great little item that will do the bull work of what you want to do. The nice thing is that it doesn’t require a separate remote turn...
Since you plan on keeping the factory head unit, You need to first verify what ohm rating your factory speakers and head unit are. Some are 4...
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
Wingman0121
